O que você precisa
Push the left tab with your left hand.
Then push the right tab with your right hand.
While your right hand is still pushing, remove the battery with your left hand.
3 outras pessoas executaram este guia.
2 comentários
Step has the incorrect screw to release the keyboard. There is no need to open the back panel. The screw which holds down the keyboard is the long screw between the Serial Number sticker and the battery release switch #2.
Agreed 100%. Good thing I looked at this comment before I ran into major trouble. Thank you!
