Ir para o conteúdo principal
Toshiba Satellite C55-C5268 Heat Sink Replacement
O que você precisa
  1. Toshiba Satellite C55-C5268 Heat Sink Replacement, Battery: passo 1, imagem 1 %32
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Heat Sink Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-C5268 Heat Sink Replacement: passo 2, imagem 2 %32
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Heat Sink Replacement, Back Panel: passo 3, imagem 1 %32
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Heat Sink Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-C5268 Heat Sink Replacement: passo 4, imagem 2 %32
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Heat Sink Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55-C5268 Heat Sink Replacement: passo 5, imagem 2 %32
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Heat Sink Replacement, Heat Sink: passo 6, imagem 1 %32 Toshiba Satellite C55-C5268 Heat Sink Replacement, Heat Sink: passo 6, imagem 2 %32
    • Unscrew the four 5.0 mm screws holding the heat sink in place using #1 Phillips screwdriver.
    • The 5.0 mm screws can unscrew from the laptop, but stay attached to the heat sink.
    • One of the screws is underneath a ribbon. Be sure to gently move the ribbon out of the way first.
    • Be sure to screw the replacement heat sink in the correct way.
Conclusão
Ben Rounseville
Membro desde: 10/21/16
471 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 4-1, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 Membros
Autoria de 12 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 659
