Ir para o conteúdo principal
Toshiba Satellite C55-C5268 Battery Replacement
O que você precisa
  1. Toshiba Satellite C55-C5268 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-C5268 Battery Replacement: passo 2, imagem 2 %32
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
Conclusão
Uma outra pessoa concluiu este guia.
Greg Smith
Membro desde: 10/24/16
347 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-1, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 Membros
Autoria de 12 guias
2 comentários
Thanks, l think my battery is dead, charged it for 12 hours and base never got hot, not charging, right? Computer does not come on at all.
bribocall - Responder
Hello! i have TOSHIBA SATELLITE C55-B1065 Laptop and i’m wondering what is the good battery i should buy ?
sana aissaoui - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 85
Ao todo: 17,786
