Ir para o conteúdo principal
Toshiba Satellite C55-C5268 Back Panel Replacement Guide
O que você precisa
  1. Toshiba Satellite C55-C5268 Back Panel Replacement Guide, Battery: passo 1, imagem 1 %32
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: passo 2, imagem 1 %32 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: passo 2, imagem 2 %32
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Back Panel Replacement Guide, Back Panel: passo 3, imagem 1 %32
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: passo 4, imagem 1 %32 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: passo 4, imagem 2 %32
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: passo 5, imagem 1 %32 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: passo 5, imagem 2 %32
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
Conclusão
Uma outra pessoa concluiu este guia.
Ben Rounseville
Membro desde: 10/21/16
471 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 4-1, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 27
Duração total: 1,823
