Ir para o conteúdo principal
Toshiba Satellite C55-C5240 Screen Replacement
O que você precisa
  1. Toshiba Satellite C55-C5240 Screen Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement, Battery: passo 1, imagem 3 %32
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Screen Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 2, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 2, imagem 3 %32
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Screen Replacement, Back cover: passo 3, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement, Back cover: passo 3, imagem 2 %32
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Screen Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 4, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 4, imagem 3 %32
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Screen Replacement, Screen: passo 5, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement, Screen: passo 5, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement, Screen: passo 5, imagem 3 %32
    • Carefully disconnect these three cables.
  6. Toshiba Satellite C55-C5240 Screen Replacement: passo 6, imagem 1 %32
    • Open the laptop at a right angle to make the later removal much easier.
  7. Toshiba Satellite C55-C5240 Screen Replacement: passo 7, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 7, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 7, imagem 3 %32
    • Unscrew the four PH1 Phillips head screws on the hinges.
  8. Toshiba Satellite C55-C5240 Screen Replacement: passo 8, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 8, imagem 2 %32
    • Separate the screen from the rest of the laptop.
    • Make sure the cables do not catch on the bottom piece.
  9. Toshiba Satellite C55-C5240 Screen Replacement: passo 9, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 9, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, remove the two stickers on the bottom of the screen.
    • Unscrew the two screws underneath.
  10. Toshiba Satellite C55-C5240 Screen Replacement: passo 10, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 10, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 10, imagem 3 %32
    • Stick the plastic opening tool underneath the screen bezel and run it along the edge of the screen.
    • Loosen each hinge separately, it would be more difficult otherwise.
  11. Toshiba Satellite C55-C5240 Screen Replacement: passo 11, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 11, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 11, imagem 3 %32
    • Unscrew the four inner screws around the screen.
    • Leave the two outer screws on the top alone.
  12. Toshiba Satellite C55-C5240 Screen Replacement: passo 12, imagem 1 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 12, imagem 2 %32 Toshiba Satellite C55-C5240 Screen Replacement: passo 12, imagem 3 %32
    • Mind the cable on the bottom of the screen.
    • Simply lift the screen out.
Conclusão
4 outras pessoas executaram este guia.
Angela Rodriguez
Membro desde: 02/28/17
261 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G5, Nance Spring 2017 Membro de USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 2,587
