Introdução
Whether or not you are upgrading your storage or the hard drive is out of commission, this guide will help you remove it.
O que você precisa
Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
The hard drive is on the bottom left side.
Remove both releases from the rubber hard drive mount.
5 outras pessoas executaram este guia.
