Ir para o conteúdo principal
Toshiba Satellite C55-C5240 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 2, imagem 2 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 2, imagem 3 %32
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: passo 3, imagem 1 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement, Back cover: passo 3, imagem 2 %32
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 4, imagem 2 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 4, imagem 3 %32
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement, Hard Drive: passo 5, imagem 3 %32
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 6, imagem 2 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 6, imagem 3 %32
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 7, imagem 1 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 7, imagem 2 %32 Toshiba Satellite C55-C5240 Hard Drive Replacement: passo 7, imagem 3 %32
    • Peel off the rubber hard drive mount.
Conclusão
5 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S1-G5, Nance Spring 2017 Membro de USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
Membros da 3
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 23
Duração total: 1,672
