Ir para o conteúdo principal
Toshiba Satellite C55-B5302 laptop Memory chip (RAM) Replacement
O que você precisa
  1. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: passo 1, imagem 2 %32
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 2, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 3, imagem 1 %32
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, imagem 1 %32 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, imagem 2 %32 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): passo 4, imagem 3 %32
    • Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, imagem 2 %32 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: passo 5, imagem 3 %32
    • Push down on the two clips holding the RAM chip in place.
    • Pull the RAM chip up slightly and out away from the connection to remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 1,097
