Introdução
Use this guide to remove the memory chip from your Toshiba Satellite C55-B5302 laptop. You will need a Phillips #0 screwdriver and a plastic opening tool. Make sure your laptop is unplugged and cool before you start. The memory chip is easy to remove and should take 10 to 15 minutes.
O que você precisa
Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
