Ir para o conteúdo principal
Toshiba Satellite C55-B5302 Fan Replacement
O que você precisa
  1. Toshiba Satellite C55-B5302 Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-B5302 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-B5302 Fan Replacement: passo 2, imagem 2 %32
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Fan Replacement: passo 3, imagem 1 %32
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Fan Replacement, Fan: passo 4, imagem 1 %32 Toshiba Satellite C55-B5302 Fan Replacement, Fan: passo 4, imagem 2 %32 Toshiba Satellite C55-B5302 Fan Replacement, Fan: passo 4, imagem 3 %32
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Fan Replacement: passo 5, imagem 1 %32
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Fan Replacement: passo 6, imagem 1 %32 Toshiba Satellite C55-B5302 Fan Replacement: passo 6, imagem 2 %32 Toshiba Satellite C55-B5302 Fan Replacement: passo 6, imagem 3 %32
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Fan Replacement: passo 7, imagem 1 %32
    • You can now lift the fan out of the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 476
