Ir para o conteúdo principal
Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: passo 2, imagem 1 %32
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 1 %32 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 2 %32 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 3 %32
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
    to remove the back, you have to remove all the philips screws. and then, it took some gentle but firm prying to get the back off.
    tom - Responder
    Missing steps. You need to take the cover off by removing all the screws and prying gently.
    it is useless and unacceptable to have a guide without showinng all the steps!!! Please do better in the future!
    gerasim - Responder
Conclusão
5 outras pessoas executaram este guia.
Pablo Andrade
Membro desde: 02/14/18
1.081 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S3-G1, Nance Spring 2018 Membro de USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Membros
Autoria de 22 guias
2 comentários
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - Responder
Dónde puedo comprar el disco duro de una laptop toshiba satellite C55
Dulce Martinez - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 19
Últimos 30 dias: 37
Ao todo: 4,700
