Ir para o conteúdo principal
Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
O que você precisa
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: passo 2, imagem 1 %32
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 1 %32 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 2 %32 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: passo 3, imagem 3 %32
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
Conclusão
5 outras pessoas executaram este guia.
Pablo Andrade
Membro desde: 02/14/18
1.081 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team S3-G1, Nance Spring 2018 Membro de USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
Membros da 4
Autoria de 22 guias
2 comentários
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - Responder
Dónde puedo comprar el disco duro de una laptop toshiba satellite C55
Dulce Martinez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 19
Duração total: 4,680
