Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
A guide on how to replace the disk drive on a Toshiba Satellite C55-B5200 laptop.
Peças
Nenhum componente especificado.
  1. Turn the laptop off and remove all sources of power.
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Pull the battery out of the laptop.
    • Pull the battery out of the laptop.
  3. Make sure device is turned off and unplugged
    • Make sure device is turned off and unplugged
    • Failure to do so could result in electric shock
    • Use J0 Philips Head Screwdrivers to remove 13, 6.6 mm screws on back of device
  4. Remove the remaining two, 6.6 mm screws to remove the battery Use a plastic opening tool to lift and open the back Use a plastic opening tool to lift and open the back
    • Remove the remaining two, 6.6 mm screws to remove the battery
    • Use a plastic opening tool to lift and open the back
  5. Lift and pull out disk drive
    • Lift and pull out disk drive
Conclusão
Uma outra pessoa concluiu este guia.
Pablo Andrade
Membro desde: 14-02-2018
939 Reputation
7 Guias de autoria
Equipe
USF Tampa, Team S3-G1, Nance Spring 2018 Membro de USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Membros
8 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 241
