Introdução
Battery uses a 45W (10V 2.37A) 100-240V/50-60Hz AC Adapter and a 4 cell/45Wh lithium ion battery.
O que você precisa
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
3 outras pessoas executaram este guia.
