Ir para o conteúdo principal
Toshiba Satellite C55-A5310 Optical Drive Replacement
O que você precisa
  1. Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: passo 1, imagem 3 %32
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: passo 2, imagem 1 %32 Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: passo 2, imagem 2 %32
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 3, imagem 1 %32
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 4, imagem 2 %32
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55-A5310 Optical Drive Replacement: passo 5, imagem 2 %32
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
Conclusão
Kari Rodgers
Membro desde: 02/08/18
482 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 354
