Ir para o conteúdo principal
Toshiba Satellite C55-A5302 Screen Replacement
O que você precisa
  1. Toshiba Satellite C55-A5302 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Screen Replacement: passo 2, imagem 1 %32
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Screen Replacement: passo 3, imagem 1 %32
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Screen Replacement, Screen: passo 4, imagem 1 %32
    • Use tweezers to remove the screw covers in the lower corners of the screen.
  5. Toshiba Satellite C55-A5302 Screen Replacement: passo 5, imagem 1 %32
    • Use the Phillips #1 screwdriver to unscrew the two screws in the lower corners of the screen.
  6. Toshiba Satellite C55-A5302 Screen Replacement: passo 6, imagem 1 %32 Toshiba Satellite C55-A5302 Screen Replacement: passo 6, imagem 2 %32
    • Start popping off the cover all the way around the screen until it comes off.
  7. Toshiba Satellite C55-A5302 Screen Replacement: passo 7, imagem 1 %32 Toshiba Satellite C55-A5302 Screen Replacement: passo 7, imagem 2 %32
    • Remove the two screws in the top corners with a Phillips #1 screwdriver. The screen will pop forward after removing the two screws.
    • Using the same Phillips #1 screwdriver, remove the three screws on the side of screen frame.
  8. Toshiba Satellite C55-A5302 Screen Replacement: passo 8, imagem 1 %32 Toshiba Satellite C55-A5302 Screen Replacement: passo 8, imagem 2 %32
    • On the back of screen, lift up the plastic film and screen connector. Pop out the connector, and gently remove the screen.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 26
Duração total: 658
