Ir para o conteúdo principal
Toshiba Satellite C55-A5302 ODD Replacement
O que você precisa
  1. Toshiba Satellite C55-A5302 ODD Replacement, Battery: passo 1, imagem 1 %32
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 ODD Replacement: passo 2, imagem 1 %32
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 ODD Replacement: passo 3, imagem 1 %32
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 ODD Replacement, Hard Drive: passo 4, imagem 1 %32
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 ODD Replacement: passo 5, imagem 1 %32
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 ODD Replacement: passo 6, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 ODD Replacement: passo 7, imagem 1 %32
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
  8. Toshiba Satellite C55-A5302 ODD Replacement, Optical Disk Drive: passo 8, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove the two screws under the hard drive.
  9. Toshiba Satellite C55-A5302 ODD Replacement: passo 9, imagem 1 %32
    • Use a metal spudger and run it along the edges of the computer to take off the plastic back cover. (Starting near a port usually allows more space for the spudger to be inserted)
  10. Toshiba Satellite C55-A5302 ODD Replacement: passo 10, imagem 1 %32
    • Slowly work from one end to the other to lift the back cover off.
  11. Toshiba Satellite C55-A5302 ODD Replacement: passo 11, imagem 1 %32 Toshiba Satellite C55-A5302 ODD Replacement: passo 11, imagem 2 %32
    • Grab hold of the optical drive and elevate it slightly and remove it from the computer.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 406
