Introdução
In this guide, you will learn how to take off the back cover of the Toshiba Satellite C55-A5302 and replace the HDD.
Peças
Não são necessárias peças.
  1. Power down the laptop and remove all power cords. After this is done, turn the laptop over.
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Slide the battery latches outwards away from the center of the device.
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Lift and remove the battery from the device.
    • Lift and remove the battery from the device.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  6. Remove the middle plastic cover to expose the hard drive.
    • Remove the middle plastic cover to expose the hard drive.
  7. Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  8. Remove the three screws using the Phillips #1 screwdriver.
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
Conclusão
Visualizar Estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Todo: 75
