Ir para o conteúdo principal
Toshiba Satellite C55-A5300 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite C55-A5300 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-A5300 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-A5300 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-A5300 Hard Drive Replacement: passo 2, imagem 2 %32 Toshiba Satellite C55-A5300 Hard Drive Replacement: passo 2, imagem 3 %32
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 Hard Drive Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 Hard Drive Replacement: passo 6, imagem 1 %32
    • Pull the silver tab connected to the hard drive up to take it out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 549
