Ir para o conteúdo principal
Toshiba Satellite C55-A5300 Fan Replacement
O que você precisa
  1. Toshiba Satellite C55-A5300 Fan Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-A5300 Fan Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-A5300 Fan Replacement, Battery: passo 1, imagem 3 %32
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-A5300 Fan Replacement: passo 2, imagem 2 %32 Toshiba Satellite C55-A5300 Fan Replacement: passo 2, imagem 3 %32
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 Fan Replacement, Hard Drive: passo 3, imagem 1 %32
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 Fan Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 Fan Replacement: passo 5, imagem 1 %32
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 Fan Replacement: passo 6, imagem 1 %32
    • Pull the silver tab connected to the hard drive up to take it out.
  7. Toshiba Satellite C55-A5300 Fan Replacement, Fan: passo 7, imagem 1 %32
    • Using the PH1 screwdriver, remove the remaining screws from the back casing of the laptop.
  8. Toshiba Satellite C55-A5300 Fan Replacement: passo 8, imagem 1 %32
    • Use a nylon spudger or plastic opening tool to carefully wedge the casing apart and remove the back plate of the laptop.
  9. Toshiba Satellite C55-A5300 Fan Replacement: passo 9, imagem 1 %32 Toshiba Satellite C55-A5300 Fan Replacement: passo 9, imagem 2 %32
    • Remove the 2 screws holding the fan in place.
  10. Toshiba Satellite C55-A5300 Fan Replacement: passo 10, imagem 1 %32 Toshiba Satellite C55-A5300 Fan Replacement: passo 10, imagem 2 %32
    • Detach the multi-colored wire connecting the fan to the motherboard and pull the fan out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 408
