Ir para o conteúdo principal
Toshiba Satellite C55-A5286 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite C55-A5286 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Unplug the AC adapter and all other auxiliary components from the laptop.
  2. Toshiba Satellite C55-A5286 Hard Drive Replacement: passo 2, imagem 1 %32
    • There is a removable panel on the underside of the laptop with one 5-mm screw holding it in place.
    • Use the screwdriver to remove the screw and then remove the back panel.
  3. Toshiba Satellite C55-A5286 Hard Drive Replacement: passo 3, imagem 1 %32
    • Underneath this panel is a silver square with rubber around the edges. This is the hard drive. On the side of the hard drive nearest to the manufacturer’s label, there is a large, flat 8-mm screw that is holding the hard drive in place.
    • Use the screwdriver to remove the screw.
  4. Toshiba Satellite C55-A5286 Hard Drive Replacement: passo 4, imagem 1 %32
    • Carefully hold the sides of the hard drive with the rubber and pull the hard drive out. It should remove fairly easily.
Conclusão
Nicole Zellers
Membro desde: 11/06/18
265 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G5, Hovde Fall 2018 Membro de IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Membros
Autoria de 9 guias
1Comentário do guia
The hard drive is ‘encased’ in a foil-looking, very flexible ‘enclosure’.
On the screw-side (near the label), each corner of the foil enclosure has a rubber black stuffed between the drive and the laptop - these blocks are connected to the enclosure via a rubber ‘string’. If you pull those nubs straight up, you can pull on them towards the label to disengage the drive from its SATA interface.
William Totman - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 42
Ao todo: 1,013
