Ir para o conteúdo principal
Toshiba Satellite C55-A5286 Battery Replacement
  1. Toshiba Satellite C55-A5286 Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite C55-A5286 Battery Replacement, Battery: passo 1, imagem 2 %32 Toshiba Satellite C55-A5286 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Be sure to unplug the AC adapter and all other components from the laptop.
    • Slide the battery release tab away from the center of the laptop and hold it in place.
  2. Toshiba Satellite C55-A5286 Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-A5286 Battery Replacement: passo 2, imagem 2 %32
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Conclusão
You have now taken the battery out of the laptop. To reassemble your device, follow these instructions in reverse order, being sure to snap the battery back into place.
Sabria Abufares
Membro desde: 11/06/18
216 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G5, Hovde Fall 2018 Membro de IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Membros
Autoria de 9 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 464
