Ir para o conteúdo principal
Toshiba Satellite C55-A5140 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite C55-A5140 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Working from left to right, use plastic opening tool to lift keyboard up and out of recessed holding tray.
    • Continue to pry around the entire keyboard until it is loose enough to easily slide your fingers underneath the corners of the keyboard.
    • Once existing keyboard is removed, it can no longer be reinstalled. Be sure to have new keyboard available for installation.
    • Keyboard will make a snapping sound as it is freed from tray.
  2. Toshiba Satellite C55-A5140 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite C55-A5140 Keyboard Replacement: passo 2, imagem 2 %32
    • Using hands, gently pull keyboard out of device.
Conclusão
To reassemble your device, use tabs on new keyboard to snap into keyboard tray
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 571
