Ir para o conteúdo principal
Toshiba Satellite C55-A5100 RAM Replacement
O que você precisa
  1. Toshiba Satellite C55-A5100 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 RAM Replacement: passo 2, imagem 1 %32
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 RAM Replacement, RAM: passo 3, imagem 1 %32
    • Place the laptop with the bottom facing up.
    • Observe the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite C55-A5100 RAM Replacement: passo 4, imagem 2 %32
    • Using your Phillips #1 screwdriver, unscrew the 6mm screw on the panel, exposing the hard drive and RAM.
  5. Toshiba Satellite C55-A5100 RAM Replacement: passo 5, imagem 1 %32
    • Once the ram chip is exposed, push the two clips away from the ram chip to release it. (Clips move in direction of arrows.)
  6. Toshiba Satellite C55-A5100 RAM Replacement: passo 6, imagem 1 %32
    • The ram chip will tilt up after the clips are released.
    • Using your fingers, pull the ram chip out at a slight angle.
Conclusão
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 409
