Ir para o conteúdo principal
Toshiba Satellite C55-A5100 Optical Drive Replacement
O que você precisa
  1. Toshiba Satellite C55-A5100 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 2, imagem 1 %32
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, imagem 2 %32 Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: passo 3, imagem 3 %32
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 4, imagem 1 %32
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Optical Drive Replacement: passo 5, imagem 1 %32
    • Remove the disc drive from the device.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
Luis Alejandro Araúz - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 377
