Introdução
Replacing the optical drive in a Toshiba Satellite laptop should not be seen as difficult, but does involve opening one of the panels on the underside of the laptop.
O que você precisa
Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
Place laptop with the bottom of it facing up.
Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
3 outras pessoas executaram este guia.
Um comentário
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
