Ir para o conteúdo principal
Toshiba Satellite C55-A5100 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite C55-A5100 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Hard Drive Replacement: passo 2, imagem 1 %32
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Hard Drive Replacement: passo 4, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  5. Toshiba Satellite C55-A5100 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55-A5100 Hard Drive Replacement: passo 5, imagem 2 %32
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 950
