Ir para o conteúdo principal
Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement
O que você precisa
  1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: passo 1, imagem 1 %32 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: passo 1, imagem 2 %32 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: passo 1, imagem 3 %32
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  2. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: passo 2, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  3. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: passo 3, imagem 1 %32 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: passo 3, imagem 2 %32
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  4. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: passo 4, imagem 1 %32 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: passo 4, imagem 2 %32
    • Unscrew all 15 of the screws in the back cover of the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  5. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: passo 5, imagem 2 %32 Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: passo 5, imagem 3 %32
    • Unscrew the two silver screws attaching the fan to the case.
    • Unplug the power connector for the fan.
    • Pull the fan up out of the slot.
Conclusão
3 outras pessoas executaram este guia.
Rei Rutkowski
Membro desde: 11/26/18
184 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S8-G8, Wilson Fall 2018 Membro de IUPUI, Team S8-G8, Wilson Fall 2018
IUPUI-WILSON-F18S8G8
4 Membros
Autoria de 6 guias
1Comentário do guia
The one I disassembled didn’t have a screw under the battery bay, but did have one under the HDD bay, just as described by a comment in the charge port replacement guide.
Luis Alejandro Araúz - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 1,058
