Ir para o conteúdo principal
Toshiba Satellite C50D-A RAM Replacement
O que você precisa
  1. Toshiba Satellite C50D-A RAM Replacement, Battery: passo 1, imagem 1 %32
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite C50D-A RAM Replacement: passo 2, imagem 2 %32
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A RAM Replacement, Lower Case: passo 3, imagem 1 %32 Toshiba Satellite C50D-A RAM Replacement, Lower Case: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A RAM Replacement: passo 4, imagem 1 %32
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A RAM Replacement: passo 5, imagem 1 %32
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A RAM Replacement: passo 6, imagem 1 %32 Toshiba Satellite C50D-A RAM Replacement: passo 6, imagem 2 %32 Toshiba Satellite C50D-A RAM Replacement: passo 6, imagem 3 %32
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A RAM Replacement, RAM: passo 7, imagem 1 %32
    • Using your fingers, unclip the two side clips.
  8. Toshiba Satellite C50D-A RAM Replacement: passo 8, imagem 1 %32 Toshiba Satellite C50D-A RAM Replacement: passo 8, imagem 2 %32
    • The RAM should now be at a 30 degree angle.
    • Using your fingers, unclip the top two clips.
    • The RAM should just pop out. You can remove it with your fingers.
    • This will apply to either top or bottom RAM.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 818
