Ir para o conteúdo principal
Toshiba Satellite C50D-A Fan Replacement
O que você precisa
  1. Toshiba Satellite C50D-A Fan Replacement, Battery: passo 1, imagem 1 %32
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A Fan Replacement: passo 2, imagem 1 %32 Toshiba Satellite C50D-A Fan Replacement: passo 2, imagem 2 %32
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A Fan Replacement, Lower Case: passo 3, imagem 1 %32 Toshiba Satellite C50D-A Fan Replacement, Lower Case: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A Fan Replacement: passo 4, imagem 1 %32
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A Fan Replacement: passo 5, imagem 1 %32
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A Fan Replacement: passo 6, imagem 1 %32 Toshiba Satellite C50D-A Fan Replacement: passo 6, imagem 2 %32 Toshiba Satellite C50D-A Fan Replacement: passo 6, imagem 3 %32
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A Fan Replacement, Fan: passo 7, imagem 1 %32 Toshiba Satellite C50D-A Fan Replacement, Fan: passo 7, imagem 2 %32 Toshiba Satellite C50D-A Fan Replacement, Fan: passo 7, imagem 3 %32
    • Using a Phillips #1 screwdriver, remove the one 1.5mm screw.
  8. Toshiba Satellite C50D-A Fan Replacement: passo 8, imagem 1 %32
    • Lift the fan up and blow compressed air or replace with a new one.
    • Blow compressed air into the spirals in the middle of the fan.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 15
Ao todo: 1,325
