Ir para o conteúdo principal
Toshiba Satellite A85-S107 15" Disc Drive Replacement
O que você precisa
  1. Toshiba Satellite A85-S107 15" Disc Drive Replacement, Battery: passo 1, imagem 1 %32
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Disc Drive Replacement: passo 2, imagem 1 %32
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Disc Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite A85-S107 15" Disc Drive Replacement: passo 3, imagem 2 %32
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Disc Drive Replacement, Disc Drive: passo 4, imagem 1 %32 Toshiba Satellite A85-S107 15" Disc Drive Replacement, Disc Drive: passo 4, imagem 2 %32
    • Flip the laptop over and orient it so that the battery faces away from you.
    • Remove the 5mm Phillips #0 screw on the bottom case.
  5. Toshiba Satellite A85-S107 15" Disc Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite A85-S107 15" Disc Drive Replacement: passo 5, imagem 2 %32 Toshiba Satellite A85-S107 15" Disc Drive Replacement: passo 5, imagem 3 %32
    • Insert the plastic opening tool into the gap between the disk drive and the laptop and pop out the disk drive.
    • Slid the disc drive out of its slot on the left side of the computer. It should slide out easily.
Conclusão
Alana
Membro desde: 04/14/13
96 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 10-38, Amido Spring 2013 Membro de Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
Membros da 4
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 576
