Ir para o conteúdo principal
Toshiba Satellite A75-S226 Display Assembly Replacement
O que você precisa
  1. Toshiba Satellite A75-S226 Display Assembly Replacement, Wi-Fi/Memory Cover: passo 1, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement, Wi-Fi/Memory Cover: passo 1, imagem 2 %32
    • Remove the 5.75 mm screw from the cover panel.
    • Turn the laptop over with the screen facing down.
  2. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 2, imagem 1 %32
    • Lift up the cover panel using a plastic opening tool.
  3. Toshiba Satellite A75-S226 Display Assembly Replacement, Wi-Fi Card: passo 3, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement, Wi-Fi Card: passo 3, imagem 2 %32
    • Remove the 5.64 mm screw from the bottom of the crossing bar.
    • Remove the crossing bar.
  4. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 4, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
    • Note that the black wire is connected to the port that is labeled main.
  5. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 5, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 5, imagem 2 %32
    • Use fingers to push the clips away from memory card.
  6. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 6, imagem 1 %32
    • Use fingers to remove the Wi-Fi card.
  7. Toshiba Satellite A75-S226 Display Assembly Replacement, Keyboard: passo 7, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement, Keyboard: passo 7, imagem 2 %32 Toshiba Satellite A75-S226 Display Assembly Replacement, Keyboard: passo 7, imagem 3 %32
    • Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
    • It may be helpful to first pry at the rear of the hinge covers (not shown) to release them. Then Insert the plastic opening tool underneath the top panel's sides and then front edge.
  8. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 8, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 8, imagem 2 %32
    • Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
  9. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 9, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 9, imagem 2 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 9, imagem 3 %32
    • Remove the two 3.67 mm screws from the top corners of the keyboard.
  10. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 10, imagem 1 %32
    • Use fingers to lift up the keyboard from the top.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  11. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 11, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 11, imagem 2 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 11, imagem 3 %32
    • Remove the cable connecting the keyboard with the motherboard.
    • Be aware of the locking tabs on each side of the ribbon-cable connector—they slide back about 2mm to free the cable.
    • Lift up and remove the keyboard.
  12. Toshiba Satellite A75-S226 Display Assembly Replacement, Display Assembly: passo 12, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement, Display Assembly: passo 12, imagem 2 %32
    • Remove the 3.76mm screw from the ground wire.
  13. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 13, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 13, imagem 2 %32
    • Use the plastic opening tool to remove the wire.
  14. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 14, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 14, imagem 2 %32
    • Gently pull the black and white wires out of the upper case.
    • Do not pull the wire too much, or you can damage the wire.
  15. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 15, imagem 1 %32
    • Remove the 8.6 mm screw on left side of upper case.
  16. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 16, imagem 1 %32 Toshiba Satellite A75-S226 Display Assembly Replacement: passo 16, imagem 2 %32
    • Remove two 8.6 mm screws on the back corners of the laptop.
  17. Toshiba Satellite A75-S226 Display Assembly Replacement: passo 17, imagem 1 %32
    • Lift up the display assembly to remove it.
    one of the 14 screws identified in the diagram of step 25 was previously removed with the CD drive
    Steve - Responder
Conclusão
Replace the old display assembly with your new assembly. To reassemble your device, follow these instructions in reverse order.
Garrett Gudgel
Membro desde: 10/05/10
763 Reputação
Autoria de 13 guias
Equipe
Cal Poly, Team 4-43, Amido Fall 2010 Membro de Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
Membros da 5
Autoria de 39 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 6,373
