Ir para o conteúdo principal
Toshiba Satellite A665-S5170 Battery Replacement
O que você precisa
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A665-S5170 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: passo 2, imagem 1 %32
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite A665-S5170 Battery Replacement: passo 3, imagem 2 %32 Toshiba Satellite A665-S5170 Battery Replacement: passo 3, imagem 3 %32
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
Conclusão
Chelsea Teague
Membro desde: 10/30/16
385 Reputação
Autoria de 2 guias
Equipe
Baylor, Team 4-5, Williams Fall 2016 Membro de Baylor, Team 4-5, Williams Fall 2016
BU-WILLIAMS-F16S4G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 1,162
