Ir para o conteúdo principal
Toshiba Satellite A660-ST3NX2X RAM Replacement
O que você precisa
  1. Toshiba Satellite A660-ST3NX2X RAM Replacement, Battery: passo 1, imagem 1 %32
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 2, imagem 1 %32 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 2, imagem 2 %32
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 3, imagem 1 %32 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 3, imagem 2 %32 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 3, imagem 3 %32
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: passo 4, imagem 1 %32 Toshiba Satellite A660-ST3NX2X RAM Replacement, RAM Memory: passo 4, imagem 2 %32
    • Use a J00 bit to unscrew the single 4mm screw that leads to the RAM Memory compartment.
  5. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 5, imagem 1 %32
    • Open the hatch that holds the RAM cards.
  6. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 6, imagem 1 %32 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 6, imagem 2 %32
    • Pull apart the two metal tabs that are holding the RAM cards in place.
    • You will feel the card pop up from its held position, indicating it can safely be pulled out.
  7. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 7, imagem 1 %32 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 7, imagem 2 %32
    • Pull out the top RAM card.
  8. Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 8, imagem 1 %32 Toshiba Satellite A660-ST3NX2X RAM Replacement: passo 8, imagem 2 %32
    • Use tabs on the sides of the bottom RAM card to release the RAM card.
    • Remove the bottom RAM card, just as the top RAM card was removed.
Conclusão
Cassie Pickett
Membro desde: 03/20/17
201 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team S8-G1, Bennett Spring 2017 Membro de Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 439
