Ir para o conteúdo principal
Toshiba Satellite A660-ST3NX2X Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 2, imagem 2 %32
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, imagem 2 %32 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 3, imagem 3 %32
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Unplug all devices from your computer and power down the device completely.
    • Flip the computer over so the screen is facing down.
    • In the image, the hard drive will appear to be in the top right corner where the box indicates.
  5. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 5, imagem 2 %32
    • Use a J00 bit to unscrew the single 4mm screw that holds the hard drive cover in place.
  6. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 6, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: passo 6, imagem 2 %32
    • Remove the cover that holds the hard drive in place.
    • Remove the hard drive.
    • This computer contains no hard drive, therefore we are unable to show the physical removal of it.
Conclusão
Cassie Pickett
Membro desde: 03/20/17
201 Reputação
Autoria de 2 guias
Equipe
Texas Tech, Team S8-G1, Bennett Spring 2017 Membro de Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 569
