Ir para o conteúdo principal
Toshiba Satellite A660-ST3NX2X Battery Replacement
O que você precisa
  1. Toshiba Satellite A660-ST3NX2X Battery Replacement, Battery: passo 1, imagem 1 %32
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 2, imagem 2 %32
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 3, imagem 1 %32 Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 3, imagem 2 %32 Toshiba Satellite A660-ST3NX2X Battery Replacement: passo 3, imagem 3 %32
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
Conclusão
Megan Murrell
Membro desde: 03/20/17
322 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team S8-G1, Bennett Spring 2017 Membro de Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 573
