Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the laptop over so the bottom is facing up.
Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
Remove the WIFI module cover. It will pull right off.
Unplug the white and black wires from the WiFi module.
Remove the twelve 8mm button head Phillips #00 B8 screws.
Remove the two 14 mm button head Phillips #00 B14 screws.
Remove the two 10 mm Phillips #00 battery compartment screws.
Remove the two 8 mm Phillips #00 screws.
Remove the seven 4mm flat Phillips #00 screws.
Remove the seven 20mm button head Phillips #00 screws.
Use the plastic opening tool to pry the two halves apart.
Slide the optical drive out of the laptop through the opening on the left side of the bottom assembly.
Um comentário
Or, simply remove the screw (the center one in this photo) from the bottom case that holds the bracket in and pull the drive out.
