Ir para o conteúdo principal
Toshiba Satellite A65-S126 Internal Fan Replacement
O que você precisa
  1. Toshiba Satellite A65-S126 Internal Fan Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Internal Fan Replacement: passo 2, imagem 1 %32
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Internal Fan Replacement, Upper Assembly: passo 3, imagem 1 %32
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Internal Fan Replacement: passo 4, imagem 1 %32
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Internal Fan Replacement: passo 5, imagem 1 %32 Toshiba Satellite A65-S126 Internal Fan Replacement: passo 5, imagem 2 %32
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Internal Fan Replacement: passo 6, imagem 1 %32
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Internal Fan Replacement: passo 7, imagem 1 %32
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Internal Fan Replacement: passo 8, imagem 1 %32
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Internal Fan Replacement, Internal Fan: passo 9, imagem 1 %32
    • Remove the three 2 mm Phillips #00 screws that secure the fan to the motherboard.
  10. Toshiba Satellite A65-S126 Internal Fan Replacement: passo 10, imagem 1 %32
    • Remove the small plug connecting the fan power cable to the motherboard.
    • Carefully lift the fan out of the computer.
Conclusão
Uma outra pessoa concluiu este guia.
Cole Uhland
Membro desde: 09/30/13
216 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-8, Forte Fall 2013 Membro de Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,008
