Ir para o conteúdo principal
Toshiba Satellite A305-S6848 LCD Screen Replacement
O que você precisa
  1. Toshiba Satellite A305-S6848 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 2, imagem 1 %32
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 3, imagem 1 %32
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32 Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: passo 4, imagem 2 %32
    • Remove the 6 rubber tabs on the housing using the metal spudger.
  5. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 5, imagem 1 %32 Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 5, imagem 2 %32
    • Remove the six 5.8 mm screws using the Phillip's #0 screwdriver.
  6. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 6, imagem 1 %32
    • Pry out plastic housing on all sides.
  7. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 7, imagem 1 %32 Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 7, imagem 2 %32
    • Pry out the bottom left and right locking pieces of the plastic housing with the metal spudger.
  8. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 8, imagem 1 %32 Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 8, imagem 2 %32
    • Remove the four 5.8 mm screws using the Phillip's #0 screwdriver.
  9. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 9, imagem 1 %32
    • Remove the eight 6.5 mm screws on the left and right sides of the screen using the Phillip's #0 screwdriver.
  10. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 10, imagem 1 %32 Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 10, imagem 2 %32
    • Pull the screen down.
    • Pull off tape and take our video connector.
  11. Toshiba Satellite A305-S6848 LCD Screen Replacement: passo 11, imagem 1 %32
    • Remove cold cathode fluorescent light bulb connector.
Conclusão
Joshua E Hong
Membro desde: 11/06/17
449 Reputação
Autoria de 4 guias
Equipe
Baylor, Team S8-G1, Johnson Fall 2017 Membro de Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 509
