Ir para o conteúdo principal
Toshiba Satellite A305-S6848 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite A305-S6848 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 2, imagem 1 %32
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 3, imagem 1 %32
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • The keyboard is held in by a locking strip between the screen and the keyboard.
  5. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 5, imagem 1 %32
    • Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
  6. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 6, imagem 1 %32
    • Use your hand to take out locking strip from the right portion that was pried out.
  7. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 7, imagem 1 %32 Toshiba Satellite A305-S6848 Keyboard Replacement: passo 7, imagem 2 %32
    • Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
  8. Toshiba Satellite A305-S6848 Keyboard Replacement: passo 8, imagem 1 %32 Toshiba Satellite A305-S6848 Keyboard Replacement: passo 8, imagem 2 %32
    • Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
    • Disconnect the keyboard by flipping the locking clip upwards.
Conclusão
Joshua E Hong
Membro desde: 11/06/17
449 Reputação
Autoria de 4 guias
Equipe
Baylor, Team S8-G1, Johnson Fall 2017 Membro de Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
Membros da 2
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 561
