Ir para o conteúdo principal
Toshiba Satellite A305-S6848 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite A305-S6848 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Toshiba Satellite A305-S6848 Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Remove the 5.8mm Phillip's #0 screw with Phillip's #0 screwdriver while prying plastic covering up with metal spudger.
  2. Toshiba Satellite A305-S6848 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove plastic covering.
    • Pull up the silver tab to remove the hard drive from the slot.
Conclusão
Uma outra pessoa concluiu este guia.
Joshua E Hong
Membro desde: 11/06/17
449 Reputação
Autoria de 4 guias
Equipe
Baylor, Team S8-G1, Johnson Fall 2017 Membro de Baylor, Team S8-G1, Johnson Fall 2017
BU-JOHNSON-F17S8G1
Membros da 2
Autoria de 12 guias
Um comentário
Note: There are two hard drives in this machine. One has a single screw holding it in place within the compartment, and is very straightforward. The other has two screws. After removing the latter, the drive compartment pulls out, sliding over the now empty screw holes.
Kim McCoy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 1,011
