Ir para o conteúdo principal
Toshiba Satellite A215-S7425 RAM Replacement
O que você precisa
  1. Toshiba Satellite A215-S7425 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 RAM Replacement: passo 2, imagem 1 %32
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 RAM Replacement: passo 3, imagem 1 %32
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Locate the RAM vented plastic cover in the center of the device.
  5. Toshiba Satellite A215-S7425 RAM Replacement: passo 5, imagem 1 %32 Toshiba Satellite A215-S7425 RAM Replacement: passo 5, imagem 2 %32
    • Loosen 1 Phillips 4.2 mm size captive screw and lift cover off device to expose 2 RAM sticks.
  6. Toshiba Satellite A215-S7425 RAM Replacement: passo 6, imagem 1 %32 Toshiba Satellite A215-S7425 RAM Replacement: passo 6, imagem 2 %32 Toshiba Satellite A215-S7425 RAM Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Locate 2 metal pinchers on either side of the 1st RAM stick.
    • Use a finger from each hand to push the 2 pinchers simultaneously away from the stick of RAM and towards the exterior of the case.
    • The RAM stick will automatically rise up. Gently pull out the RAM stick with one hand.
    • The use of a anti-static wrist strap while working with the RAM is advise to prevent electrostatic discharge(ESD) from damaging the RAM.
  7. Toshiba Satellite A215-S7425 RAM Replacement: passo 7, imagem 1 %32 Toshiba Satellite A215-S7425 RAM Replacement: passo 7, imagem 2 %32 Toshiba Satellite A215-S7425 RAM Replacement: passo 7, imagem 3 %32
    • To remove the 2nd RAM stick, repeat previous steps.
    • You will be unable to remove 2nd RAM stick if the first one is not removed first.
Conclusão
Marianne
Membro desde: 09/08/14
647 Reputação
Autoria de 6 guias
Equipe
Pasco Hernando, Team 5-2, Prince Fall 2014 Membro de Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
Membros da 10
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 23
Duração total: 321
