Ir para o conteúdo principal
Toshiba Satellite A215-S7425 Hard Drive Replacement
O que você precisa
  1. Toshiba Satellite A215-S7425 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the computer.
    • Disconnect the charging cable from computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Toshiba Satellite A215-S7425 Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide latches labeled #1 and #2, located outside the battery cover, away from each other.
    • Latch #1 will click over and stay while latch #2 will have to be held for battery to release.
  3. Toshiba Satellite A215-S7425 Hard Drive Replacement: passo 3, imagem 1 %32
    • Gently lift and pull the battery out of the device.
  4. Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Toshiba Satellite A215-S7425 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Locate hard drive cover opposite the battery on the lower left corner of the device.
    • Loosen 2 Phillips 4.2 mm size captive screws from cover.
    • Lift cover slightly from the edge where the screws are and pull slowly out and to the right, releasing it from its latches on the left.
  5. Toshiba Satellite A215-S7425 Hard Drive Replacement: passo 5, imagem 1 %32 Toshiba Satellite A215-S7425 Hard Drive Replacement: passo 5, imagem 2 %32 Toshiba Satellite A215-S7425 Hard Drive Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Locate the thin plastic tab folded on right side of hard drive case.
    • Hold plastic tab and gently pull tab slightly up and to the left to remove hard drive case from device.
    • To avoid damage to the hard drive or motherboard connectors; Do not pull plastic tab in a straight up direction.
    • The use of a anti-static wrist strap while working with the hard drive is advise to prevent electrostatic discharge(ESD) from damaging the hard drive.
  6. Toshiba Satellite A215-S7425 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove 4 (2 on each side) Phillips 4.1 mm size screws from case.
  7. Toshiba Satellite A215-S7425 Hard Drive Replacement: passo 7, imagem 1 %32
    • Slide case away from hard drive.
Conclusão
Uma outra pessoa concluiu este guia.
Marianne
Membro desde: 09/08/14
647 Reputação
Autoria de 6 guias
Equipe
Pasco Hernando, Team 5-2, Prince Fall 2014 Membro de Pasco Hernando, Team 5-2, Prince Fall 2014
PHSC-PRINCE-F14S5G2
Membros da 10
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 28
Duração total: 1,012
