Ir para o conteúdo principal
Toshiba Satellite A215-S4757 Display Screen Replacement
O que você precisa
  1. Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: passo 1, imagem 1 %32 Toshiba Satellite A215-S4757 Display Screen Replacement, Display Screen: passo 1, imagem 2 %32
    • First, remove the four rubber screw coverings located at the top corners and bottom corners of the screen.
    • Remove the four screws underneath each cover and place them somewhere secure.
  2. Toshiba Satellite A215-S4757 Display Screen Replacement: passo 2, imagem 1 %32 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 2, imagem 2 %32 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 2, imagem 3 %32
    • Remove the plastic paneling around the screen, and at the bottom of the display.
    • You may need a plastic opening tool to pry the back crease open.
  3. Toshiba Satellite A215-S4757 Display Screen Replacement: passo 3, imagem 1 %32 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 3, imagem 2 %32 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 3, imagem 3 %32
    • Remove the three screws on each side of the display, and place them somewhere secure.
  4. Toshiba Satellite A215-S4757 Display Screen Replacement: passo 4, imagem 1 %32 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 4, imagem 2 %32
    • Gently move the display forward so you can see the back of the component.
  5. Toshiba Satellite A215-S4757 Display Screen Replacement: passo 5, imagem 1 %32 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 5, imagem 2 %32 Toshiba Satellite A215-S4757 Display Screen Replacement: passo 5, imagem 3 %32
    • On the back of the display, there is a wire that is plugged in to the display and secured with tape.
    • Gently lift the tape, leaving it attached to the wire.
    • Pull the wire out of its socket in the display backing.
    • The display is now fully detached!
Conclusão
Uma outra pessoa concluiu este guia.
Jacob Brown
Membro desde: 10/10/16
409 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 12-2, Bennett Fall 2016 Membro de Texas Tech, Team 12-2, Bennett Fall 2016
TTU-BENNETT-F16S12G2
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 380
