Ir para o conteúdo principal
Toshiba Satellite A210 Optical Disc Drive Replacement
O que você precisa
  1. Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A210 Optical Disc Drive Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Optical Disc Drive Replacement: passo 2, imagem 1 %32 Toshiba Satellite A210 Optical Disc Drive Replacement: passo 2, imagem 2 %32
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: passo 3, imagem 1 %32 Toshiba Satellite A210 Optical Disc Drive Replacement, RAM: passo 3, imagem 2 %32
    • Remove the screw holding the RAM cover with a PH1 screwdriver.
    • Remove the RAM cover.
  4. Toshiba Satellite A210 Optical Disc Drive Replacement: passo 4, imagem 1 %32 Toshiba Satellite A210 Optical Disc Drive Replacement: passo 4, imagem 2 %32 Toshiba Satellite A210 Optical Disc Drive Replacement: passo 4, imagem 3 %32
    • Push outwards on the metal tabs to release the RAM.
    • Remove the RAM. Some force may be needed.
    • Be careful not to touch the gold pins on the RAM chips as there may be a build-up of static electricity. This can fry the parts of the chip that houses memory.
  5. Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: passo 5, imagem 1 %32 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: passo 5, imagem 2 %32 Toshiba Satellite A210 Optical Disc Drive Replacement, Optical Disc Drive: passo 5, imagem 3 %32
    • Use a PH0 screwdriver to remove the screw holding the optical drive in place.
    • Using your index finger, push the metal tab inside the RAM bay which is located directly underneath the screw-hole.
    • The optical drive will then slide out.
Conclusão
Uma outra pessoa concluiu este guia.
Bret Wilson
Membro desde: 04/11/13
274 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-5, Regan Spring 2013 Membro de Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
Membros da 4
Autoria de 18 guias
Um comentário
Question : if i this will my screen start working ng again
jessica johnson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,602
