Ir para o conteúdo principal
Toshiba Satellite A210 Keyboard Replacement
O que você precisa
  1. Toshiba Satellite A210 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Toshiba Satellite A210 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the AC adapter and all other auxiliary components from the laptop.
    • Slide the battery lock tab away from the center of the laptop to unlock the battery.
  2. Toshiba Satellite A210 Keyboard Replacement: passo 2, imagem 1 %32 Toshiba Satellite A210 Keyboard Replacement: passo 2, imagem 2 %32
    • Slide the battery release tab away from the center of the laptop and hold it.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
  3. Toshiba Satellite A210 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Unscrew the 4 highlighted screws with a PH1 screwdriver.
  4. Toshiba Satellite A210 Keyboard Replacement: passo 4, imagem 1 %32 Toshiba Satellite A210 Keyboard Replacement: passo 4, imagem 2 %32 Toshiba Satellite A210 Keyboard Replacement: passo 4, imagem 3 %32
    • Orient the laptop so that the screen is open and facing you.
    • Slide the plastic opening tool underneath the top edge of the black plastic insert.
    • Pull it off and set aside.
  5. Toshiba Satellite A210 Keyboard Replacement: passo 5, imagem 1 %32 Toshiba Satellite A210 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the 2 PH1 screws.
    • Lift the keyboard from the top being carful not to remove it fully. There is still a ribbon cable that connects the keyboard to the laptop.
  6. Toshiba Satellite A210 Keyboard Replacement: passo 6, imagem 1 %32
    • Disconnect the keyboard ribbon cable and remove the keyboard from the laptop.
Conclusão
Youlen
Membro desde: 04/11/13
40 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-5, Regan Spring 2013 Membro de Cal Poly, Team 17-5, Regan Spring 2013
CPSU-REGAN-S13S17G5
Membros da 4
Autoria de 18 guias
Um comentário
very useful. THANKS
ANDREAS - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 2,605
