Introdução
If your laptop displays an error while reading a CD or DVD, does not play audio or video properly, or CD or DVD programs do not install or encounter errors after installation, then use this guide to remove and replace your DVD drive.
O que você precisa
Remove the 3mm screw using a Phillips #00 screwdriver located beneath the RAM module cover. This screw holds the DVD drive in place.
Uma outra pessoa concluiu este guia.
