Ir para o conteúdo principal
Toshiba Satellite A205-S4577 Speaker Cover Replacement
O que você precisa
  1. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Speaker Cover Replacement: passo 2, imagem 1 %32
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: passo 3, imagem 1 %32 Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: passo 3, imagem 2 %32 Toshiba Satellite A205-S4577 Speaker Cover Replacement, Speaker Cover: passo 3, imagem 3 %32
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Speaker Cover Replacement: passo 4, imagem 1 %32
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Speaker Cover Replacement: passo 5, imagem 1 %32
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
Conclusão
Daniel Johnson
Membro desde: 04/07/13
108 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 17-6, Regan Spring 2013 Membro de Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
Membros da 5
Autoria de 33 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,297
