Ir para o conteúdo principal
Toshiba Satellite A205-S4577 RAM Replacement
O que você precisa
  1. Toshiba Satellite A205-S4577 RAM Replacement, RAM: passo 1, imagem 1 %32
    • Identify the rectangular plastic RAM cover located in the bottom part of your laptop.
    • Remove the 4mm flat-head screws on the RAM cover.
    • Use a plastic opening tool to pry the RAM cover upward.
  2. Toshiba Satellite A205-S4577 RAM Replacement: passo 2, imagem 1 %32
    • Remove the RAM cover.
  3. Toshiba Satellite A205-S4577 RAM Replacement: passo 3, imagem 1 %32
    • Press the two tabs on the side of the PC2-5300 2 GB RAM Chip to unlatch it.
    • To remove the PC2-5300 2 GB RAM Chip, pull it out at a slightly upward angle.
  4. Toshiba Satellite A205-S4577 RAM Replacement: passo 4, imagem 1 %32 Toshiba Satellite A205-S4577 RAM Replacement: passo 4, imagem 2 %32
    • To replace the ram, insert the new PC2-5300 1 GB RAM Chip you have gathered back into the laptop.
    • Make sure the notch in the middle of the stick is lined up correctly and push firmly into place.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the laptop. Repeat process for additional RAM sticks.
  5. Toshiba Satellite A205-S4577 RAM Replacement: passo 5, imagem 1 %32 Toshiba Satellite A205-S4577 RAM Replacement: passo 5, imagem 2 %32
    • To replace the ram, insert the new RAM sticks you have back into the computer.
    • Once pushed firmly into place, firmly push down and latch the RAM sticks to the computer. Repeat process for additional RAM sticks.
  6. Toshiba Satellite A205-S4577 RAM Replacement: passo 6, imagem 1 %32
    • Screw the back plate of the RAM back onto the device.
Linha de Chegada
Daniel Johnson
Membro desde: 04/07/13
108 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 17-6, Regan Spring 2013 Membro de Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
Membros da 5
Autoria de 33 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 1,383
