Ir para o conteúdo principal
Toshiba Satellite A205-S4577 Motherboard Replacement
O que você precisa
  1. Toshiba Satellite A205-S4577 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Locate the two sliding locks indicated in the photo.
    • Slide the right lock (labeled "1") to the right. It will remain in the unlocked position.
    • Slide the left lock (labeled "2") to the left and hold it in place.
  2. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 2, imagem 1 %32
    • While holding the left lock, place your finger in the indentation next to the battery and lift the battery out.
  3. Toshiba Satellite A205-S4577 Motherboard Replacement, Speaker Cover: passo 3, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement, Speaker Cover: passo 3, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement, Speaker Cover: passo 3, imagem 3 %32
    • Remove the four screws indicated in the photos using a Phillips 00 Screwdriver. Left to right: 6mm button-head, 3mm flat-head, 6mm button-head, 6mm button-head.
  4. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 4, imagem 1 %32
    • With your hands, grasp the speaker cover on the edge nearest to the screen.
    • Pry the speaker cover upward.
  5. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the speaker cover. Your laptop will look like this photo when the speaker cover has been removed.
  6. Toshiba Satellite A205-S4577 Motherboard Replacement, Keyboard: passo 6, imagem 1 %32
    • Remove the two 4mm flat-head screws indicated in the photo.
  7. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 7, imagem 1 %32
    • Slightly lift and ease the keyboard forward, toward the screen, until the tabs clear the case.
    • When all the tabs are free, slowly lift the bottom of the keyboard while keeping the top of the keyboard angled down. Continue to carefully rotate the keyboard over until you can access the ribbon cable that is still connecting it to the computer.
  8. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 8, imagem 1 %32
    • The Ribbon Cable must be disconnected here to release the keyboard.
    • Using a plastic splunger or the tip of your screwdriver gently push upward on the two black tabs securing the connection.
    • When the black plastic bar running across the cable is unseated you can slowly and carefully pull the ribbon cable free.
    • You can now lift and remove the keyboard.
  9. Toshiba Satellite A205-S4577 Motherboard Replacement, Monitor: passo 9, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement, Monitor: passo 9, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement, Monitor: passo 9, imagem 3 %32
    • Locate the gray wire on the right.
    • Detach the white end by gently pulling each socket away from the other.
  10. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 10, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 10, imagem 2 %32
    • On the left, locate the black and white wires with gold tips on the end.
    • Pull up on the wires to detach them.
  11. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 11, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 11, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 11, imagem 3 %32
    • Locate the thick tan cord on the left.
    • Slide the tan cord as shown to detach it.
  12. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 12, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 12, imagem 2 %32
    • On the right, locate the thick black wire with the white rectangular end.
    • Pull up on it to detach it.
  13. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 13, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 13, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 13, imagem 3 %32
    • Remove the four 8mm button-head screws that are located in the top right (2) and top left corners (2) of the front cover. Use a Phillips 00 Screwdriver.
  14. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 14, imagem 1 %32
    • Once all the wires are detached and screws are removed, pull up on the monitor to remove it.
    There were two additional screws on the back of the laptop I had to remove to get the screen off.
    Dylan Carter - Responder
  15. Toshiba Satellite A205-S4577 Motherboard Replacement, Front Cover: passo 15, imagem 1 %32
    • Locate the screws that are shown in the image.
    • Remove the fourteen 6mm button-head screws with a Phillips 00 Screwdriver.
  16. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 16, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 16, imagem 2 %32
    • Lift up on the front cover to remove it.
    There was an additional screw in the front cover to the right of the wireless card that I had to remove; it was already gone in earlier pictures in the walkthrough
  17. Toshiba Satellite A205-S4577 Motherboard Replacement, USB 2.0 Ports: passo 17, imagem 1 %32
    • Locate the USB 2.0 cable on the bottom right corner of the laptop.
  18. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 18, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 18, imagem 2 %32
    • Locate the white slot on the left side of the USB 2.0 wire.
    • Carefully detach the wire by pulling the cable to the right of the slot.
  19. Toshiba Satellite A205-S4577 Motherboard Replacement, Fan: passo 19, imagem 1 %32
    • Locate the 6mm flat-head screw in the top right corner of the bottom of the laptop.
    • Remove this screw with the Phillips 00 Screwdriver.
  20. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 20, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 20, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 20, imagem 3 %32
    • Locate and remove the white connector that is .75 inches wide.
  21. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 21, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 21, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 21, imagem 3 %32
    • Locate and remove the smaller white connector (far right) and any tape that is holding it down.
  22. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 22, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 22, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 22, imagem 3 %32
    • Remove any tape that is still covering the fan.
    • Remove the fan.
  23. Toshiba Satellite A205-S4577 Motherboard Replacement, Optical Drive: passo 23, imagem 1 %32
    • Locate the 4mm flat-head screw. Remove it using the Phillips 00 Screwdriver.
  24. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 24, imagem 1 %32
    • Turn the computer over.
    • Locate the optical drive on the right.
  25. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 25, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 25, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 25, imagem 3 %32
    • Using two fingers, slide the optical drive toward the edge of the computer.
    • Continue to slide the optical drive until it can be removed from the computer.
  26. Toshiba Satellite A205-S4577 Motherboard Replacement, Motherboard: passo 26, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement, Motherboard: passo 26, imagem 2 %32 Toshiba Satellite A205-S4577 Motherboard Replacement, Motherboard: passo 26, imagem 3 %32
    • Locate the two black and red wires on each side of the motherboard.
    • Slowly pull back on the cables away from the motherboard to detach them from their connector slots.
  27. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 27, imagem 1 %32 Toshiba Satellite A205-S4577 Motherboard Replacement: passo 27, imagem 2 %32
    • Pinch the plastic cable horizontally and pull it away from the socket in order to remove the cable connecting the motherboard to the speaker cover buttons.
  28. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 28, imagem 1 %32
    • Locate the black wire next to optical drive and gently pull it away from the socket to remove it.
  29. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 29, imagem 1 %32
    • Remove the six 4mm flat-head screws with a Phillips 00 Screwdriver.
  30. Toshiba Satellite A205-S4577 Motherboard Replacement: passo 30, imagem 1 %32
    • Place one hand on the side with the optical drive and one hand on the side with the fan.
    • Pull the motherboard away from the main frame at a slightly upward angle.
Conclusão
8 outras pessoas executaram este guia.
Kelly Palermo
Membro desde: 04/18/13
127 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-6, Regan Spring 2013 Membro de Cal Poly, Team 17-6, Regan Spring 2013
CPSU-REGAN-S13S17G6
5 Membros
Autoria de 33 guias
1Comentário do guia
Thank you for this guide!
smlaptoprepair - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 29
Ao todo: 5,157
